2016 GLC 300 whining noise
Old 08-05-2024, 11:11 AM
DYI_mb_fun's Avatar
2016 Mercedes GLC 300
I get the message about the battery and hear this noise (see attachment). Does anybody know what that could be and if they are related?
File Type: mov
Old 08-05-2024, 01:41 PM
sn202020's Avatar
2017 GLC 300 4Matic
"Low battery" warning.
See
System button. - Dynamic - Engine voltage
engine run 13.5volt ~ 14.9 (alternator good)
/ engine off 12.2 v ~ 12.5 (battery)
If the original battery never been changed 8 years, it's time anyway to
get a new AGM battery.
Check
alternator & Serpentine belt
Old 08-08-2024, 07:37 PM
DYI_mb_fun's Avatar
Voltage is within range when engine is off and when it’s running
Very confusing
Old 08-08-2024, 07:59 PM
sn202020's Avatar
2017 GLC 300 4Matic
Voltage might be in good range but amperage might not.
Again, the cheapest thing to do is,
If the original battery never been changed 8 years, it's time anyway to get a new AGM battery.
H7-AGM type at Costco about US$250
Or
Wait until you see more obvious symptom.
Old 08-08-2024, 11:06 PM
DYI_mb_fun's Avatar
Thanks for your help! Replaced battery and that took care of message..
Have to figure out the whining noise now
Old 08-08-2024, 11:54 PM
sn202020's Avatar
2017 GLC 300 4Matic
Your noise at 1500rpm sounds might be
- Serpentine belt
- pulleys - idler, AC, alternator, tensioner
- turbo bearing - not likely.
1. Hear and find noisy location under the hood at 1500rpm
2. Remove Serpentine belt and turn all the pulleys by hand and hear if any bearing is noisy. If possible, add some bearing grease into the noisy pulley bearing to see if it fixes. (My alternator pulley, OAD, was noisy and replaced)
3. Remove turbo intake hose and feel the fan blade bearing's play. Less than 1mm up/down and side/side is normal, I belive.
mikapen (08-24-2024)
Old 08-24-2024, 09:07 AM
DYI_mb_fun's Avatar
Ended up replacing the Alternator, Idler pulley and tensioner and that took care of the whining noise
thanks for your help!
Quick Reply: 2016 GLC 300 whining noise
