GLC brakes "adjusting" while in Park, before E brake engaged
GLC coupe 2022
2022 GLC coupe. Hopefully someone here can help! The shop says it's "normal" and could just be this GLC. I put the car in park and the brakes make a rubbing sound. Foot is off the brake and when just sitting there with the car running, the brakes start to "adjust". They make a rubbing/grinding sound. It's like the pressures are adjusting, both in the front and back, inconsistently. Something I wouldn't expect from a Mercedes. Once the door is opened, the car is turned off, or that emergency park break button is pushed, then the brakes "set" and the noise stops. Has anyone else had this problem of the brakes not setting before that parking "Park" brake is engaged?
