PLEASE HELP. I need Mercedes Fuel Pump Wiring Adapter Harness 2011 w204 c300 .
I burned mine badly & I can't find a link to a new one please help , this is my last hope 😔. I need this black wire harness , the 2 small wires are also part of the black harness it melted I can't remove it from gas pump part This is the end of harness that connect to gas pump
Im coming up with 1715450128 for the connector. Looks like that connector is used for alot of different pumps with different wiring set ups. Showing as $6.25 at my local MB dealer.
thank you so much . My benz dealership quoted me 3,000$ for the whole assembly & said you would need to buy the whole thing. Then he said he found the plugs but they are 50$ each for both ends. Your a life saver man . I will give these a shot
Hey Tim, I need this connector as well . On mine it's melted
