2016 G63 Water pump??
I started the G and the low coolant light came on....huge puddle of coolant underneath. Added coolant to the reservoir and 100% drained right out the front of the engine above the crank pulley. Guessing water pump???
Edit: Appears to be this small, hard plastic hose just above the crank pulley. See Pic. Does anyone know the part # for this hose?
Found the part # a1572000151 or 157-200-00-00
Turbo coolant line
Pretty straightforward fix. Pulled the cooling fan to get some working room, 3 bolts, a couple clamps and done. Part was $59 at local dealer. Topped off the coolant and back in action.
Turbo coolant line
Originally Posted by djantlive
Nice work. Glad it's not WP! That can take a lot more work for sure.
Turbo coolant line
Turbo coolant line
Originally Posted by DVR
Well done. My most recent service at MB Aust suggested that I replace the turbo coolant lines on both sides as the drivers side (RHS in Aust) coolant line was leaking. Quote from local dealer was A$4000!!!!
