A207 - Aircap
A207 - Aircap
Hello all,
I had my windshield replaced recently and the wind deflector at the top of the windshield now no longer sits flush. It has never worked since I bought it a year ago, but it looked fine, so I didn't bother.
The lights on the button in the center console do not work, so I assumed it was related to a fuse. However, I can't work out which fuse it should be. Any suggestions? It's (almost) the only thing that doesn't work. Windscreen wash pump is also dead, not sure it's related...
I'm prepared to buy a new (used) unit to replace the deflector if I have to, but I need to know that the electronics actually work.
Any suggestions?
Thank you!
Any suggestions?
Thank you!
Hello all,
Any suggestions?
Thank you!
Any suggestions?
Thank you!
The deflector's spring must be busted. The sunroof opens and closes okay right? If I were you do not open that sunroof until you are ready to service that part then cleab and lubricate the rails. For the centre console if the radio and outher stuff is working then the LEDs must be busted and a straight swap can be done. The windshield wash pump you should tackle as you do not want to not have a fully working windshield cleaning system when winter hits.
I am talking about the convertible and the deflector at the top of the windshield, not the coupe and the deflector that pops up when you open the sunroof.
