TPMS Hell?
TPMS Hell?
Last week I got a TPMS error...pressure on the tire was fine. So, I reset it about a dozen times and setup a service call at Discount Tire. They replace the offending TPMS in the DS Rear wheel...seemed to have resolved the issue.
Today...TMPS Sensor going off again. Tire went from 47 to 48lbs...sensor went off. Parked car for about two hours - driving away, pressure down to 46...light turned on....over and over and over.
So - what is my next play here...wise ones of the internet?
Received 3,543 Likes
MY'14 W212 M276 3.5NA @60kMi
TPMS module
It sounds like TPMS did its job to warn you of pressure issue, right?
Continental TPMS is a reliably soldered module located on top of passenger rear axle. It's an alarm of pressure differentials: current vs. stored thresholds.
Perhaps your module got swamped through its connector... see how it responds to your scanner.
Isn't 46PSI above limit for (cold) tire pressure??
Received 2,087 Likes
My cold pressures are 40-42psi on a 2014 sedan all corners, but it's just me at mix of street and highway driving
Are you carrying payload and lots of passengers at highway speeds frequently?
is it always the drivers rear wheel giving these issues? I've had issues with discount tire "new" sensors before on another car - they replaced them and it was all good
Received 3,911 Likes
2019 C63CS
You'll have to find out if it keeps going off because it can't communicate with the new sensor or because the new sensor is faulty as well. Or maybe it's one of the remaining sensors that coincidently went out as well. How old is your car? The batteries in the TPMS sensors last 5-10 years, depending on driving habits. The more you drive, the more they are active and the battery drains faster. While the car is parked, they go to sleep to preserve the battery. If one of the sensors goes out, the others won't be far behind, so might as well replace them all together.
CaliBenzDriver (Today)
Talked to my mechanic today, he said to NOT reset the light. Add pressure when it is low and see if that resolves the odd lights.
-let about 10 psi out of all- reset. Go back up - reset. All while the engine is running and the system is active....we shall see.
Then, went to Wawa, the free air did not work. Three CircleK had out right cut air (and vacuum) hoses..people suck.
time for OBD Scan
You can hook up your trusted OBD scanner to read TPMS datastreams.
Before we all loose our marbles... let me say TPMS works over CAN-B which is loaded with the most modules.
Meaning IC Display and TPMS may be having trouble communicating in realtime speed.
See what sort of fault you've got on CAN-B....
++++ Junk traffic on CAN-B used to drive my TPMS module silly. The module itself is A1 grade.
2019 C63CS
The old one was replaced for the same behavior - setting of a tire light going down OR up (heat). Base line is 46 on them (wagon).
OldManAndHisCar (Today)
