2015 GLK250 front/rear brake pads and rotor torque specs
Old Yesterday, 03:31 PM
TARGETZ's Avatar
2015 GLK250 bluetec
I did a group search and seen torque specs for the GLK350 but not sure if the 2015 GLK250 bluetec has the same toque specs?
Wheel bolt:
150Nm ~ 110 ft-lbs
Front brake caliper mount external torx flange bolt:
180Nm ~ 133 ft-lbs
Rear brake caliper mount hex bolt:
120Nm ~ 88.5 ft-lbs
Front floating caliper guide pin hex flange bolt:
29Nm ~ 21 ft-lbs
Rear floating caliper guide shoulder screw:
34Nm ~ 25 ft-lbs
Are these the correct torque specs for my 2015 GLK250 bluetec?
thank you in advanced
Old Yesterday, 03:51 PM
andreigbs's Avatar
GLK 250
Those numbers look close enough to me. There shouldn't be much (if any) difference between fastener torque figures across the GLK range, whether gas or diesel.
Old Yesterday, 09:59 PM
TARGETZ's Avatar
2015 GLK250 bluetec
I have a diesel. I just wasn't sure if there was a difference between the GLK 350 and 250 brake system? ir calipers etc etc
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Quick Reply: 2015 GLK250 front/rear brake pads and rotor torque specs
