I have a 2004 clk500 can I add an aux
I was wondering if there is any way to find out if I can add an aux to my car I've looked in the glove box and it's not there I've also looked under the carpet looking for the white connector I don't know if I've missed it or if my car just doesn't have it and if there is any other way to add an aux
Check the left wall in the glovebox, there should be one. If not just get a Bluetooth Transciever, but a good quality one if setup right you wont be able to tell a difference
2014 CLS550 Weistec 540/715 Tune, 2001 E430, 2009 CLK350
On my 2009 CLK350, I pulled the cover off of the end of the dashboard and the aux jack was rolled up in there. It had never been installed. I just punched out the pre-cut hole in the glove box and pushed it in. Works great. Maybe you'll get lucky and it will be in there.
From what I understand some cars have a connector under the trim at the bottom of the passenger door. Others require removing the stereo head unit and plugging it into the back. I have looked in my 2007 CLK 350 and could not find one on the passenger side. My next step is to take apart the center console and see if I can plug one in to the back of my head unit. Maybe you will be lucky and have it rolled up beside the glove box but if not I think all CLKs could have an aux installed.
