C63 AMG (W204) 2008 - 2015
ESP/abs module needed for 09 c63 w204
Old 09-19-2024, 12:04 PM
sgltrac's Avatar
2009 c63
If anyone has a line on a ESP/ABS Module please pass it along. I do not need the motor or valve block. Must be from 09-10 c63. Dealer wants $1800 plus programming labor.
tks in advance.
Old 09-19-2024, 07:06 PM
GRP
GRP's Avatar
2010 C63
The electronics can be repaired and no reprogramming will be required. - a simple search will find your answers.
A new or secondhand unit will need reprogramming.
Old 09-19-2024, 07:22 PM
sgltrac's Avatar
2009 c63
I e already traveled the rebuild route. This module cannot be repaired.
Old 09-20-2024, 09:07 AM
manuelsm's Avatar
C63 amg
https://www.ebay.com/itm/203967523689
Old Yesterday, 12:34 PM
sgltrac's Avatar
2009 c63
I was put in touch with a seller of a used abs assembly with motor and module through this forum. The module has identical numbers on it. Is there a decent chance it will end up being plug and play? Is the dealer able (willing) to perform reprogramming if needed?
Thank you
Old Today, 09:22 AM
manuelsm's Avatar
C63 amg
its not plug and play, you have to get it programmed to your vin
Quick Reply: ESP/abs module needed for 09 c63 w204
