well one of the first modes I made is brakes cause y love brake and I use the car for climb hill with time with a brother I order some black series brakes wheel the spacers than sell in eBay and the rotors of 390 mm
have to say this is one of the best modes I have dono in the c63's I already build and the power of braking is different and this don't fade any more
390 mm Rotor is this the OEM size ?
I think not but dont know for true.
Have you done a capillar modification ( spacers ) ?
What brand is the disc ? From Brembo you get the same too for this car.
the black series has 390 mm and yes I use some spacers than sell on eBay and the rotor is from icooh dices they made them
private label for the oil catch can fittings new water hose and tensioner and belt new coolant tank don't know the name of this part but need to fit the ecu cover new zx series coils
ptfe hose for the pcv and the oil catch can vrp headers syncro design work front arms pahsers stage 3 titanium bots titanium bolts for the pasher plates new pins for the washers black series lifters skeleton plates new under bar for c63 discontinued new hangers for the subframe strut bar oil filter cap vip pulleys
carbon fiber driveshaft for the driveshaftshop new acv and the fittings thermal spacers from vrp sai platea from vip new steering wheel new cover for the headligths new thermostat 63motor cams
Originally Posted by Specvtec
/QUOTE]
Would like to know where you got the AMG labelled filler cap, as the part # you show points to a non-labelled cap in the parts catalog?
oh no no no is the part number for the gas cap then i order a cover cap from ebay and make it fit perfectly and looks oem [/QUOTE]
Ahhh understood. Do you have a link?
