Spare tire? options?
https://modernspare.com/?s=&ymm_sear...des&_model=EQS
I have 21" on my car. I've heard/read that you shouldn't mix sizes, even for a short time. I can't find a 21" version on their site. You can't beat the price though.
Anyone know if that 1 inch difference would be an issue if you had a flat in the middle of nowhere and had to drive a good distance to get it repaired?
For instance, I have a modern spare for my 23 E450. Does not matter if i am running 18 inch wheels with 245!45 tires or 19 inch wheels with 245/40 tires, the ultimate diameter is the same, and the same spare works for either set of wheels.
It's unlikely that I would need to get down and dirty to actually change the wheel, but I did add a $9 wheel alignment pin to the lug nut bolts bag so I could actually get the wheel into position.
https://www.amazon.com/dp/B08LMF53L1...n_title_1&th=1
Maybe this one will work: 😊
https://www.amazon.com/dp/B08LMF53L1?ref=cm_sw_r_cp_ud_dp_QTN4EKQ99H4PEZ2HAC ZY&ref_=cm_sw_r_cp_ud_dp_QTN4EKQ99H4PEZ2HACZY&soci al_share=cm_sw_r_cp_ud_dp_QTN4EKQ99H4PEZ2HACZY&th= 1
$1,300 for the rear pair for Pirellis
Do you ever consider getting the:
Protect your purchase with Certificates (Discount Tire)With Certificates, we’ll repair or replace your tires due to unforeseen damage–no questions asked.
view details
$235.00 for two tires
I buy them and they never question anything. They always get me another tire within a day if not in stock.
QUOTE]
How do you like those PZ4’s?
QUOTE]
view details
Also, noticed in your profile you're in Atlanta also with the same model year as me. Nice to see another Atlantan chime in.
Put it on the front and drove it and then on the back and drove it. Clears the brake calipers just fine and the overall diameter matches up well with the low profile tires.
It came with 40 lb inflation but the tire info says to go up to 60 lb before use.
Odd that this spare tire is listed for other Mercedes class vehicles but not the S class. But AI researching indicated this would work with S class. And its recommended use is limited to 50 miles.
