2015 G550 ran out of gas, wont start, and kills relays.
This relay was buzzing even with the key out of the ignition and even after disconnecting the battery, waiting 30 minutes to reset the computer, and reconnecting it. I replaced it with the same part number, the car started and ran great for about a minute then died and the new relay was already buzzing and dead.
1. What circuit does this specific relay control in the passenger footwell fuse box on a 2015 G550? (See photos attached. Startmycar.com does not state function of this relay)
2. What would cause it to keep failing? could running out of gas maybe damage the fuel pump which is now killing the relays? If so, how can I test without killing my last good relay.
Photo of the fuse box and relay position circled in red attached below.
Any help or thoughts are greatly appreciated. Thank you.
