E-Class (W211) 2003-2009
Does my sbc need replacement
Old May 13, 2026 | 01:14 AM
Nev04e320's Avatar
E320
Pulled these codes. Does this mean my sbc is failing and should be covered under the recall?
Old May 13, 2026 | 07:40 AM
SpiderMan713's Avatar
2005 E320 4-Matic Wagon and 2016 E350 4-Matic Wagon
According to SBC Extended Warranty USA, yes pressure reservoir is covered in USA.
Old May 13, 2026 | 10:07 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Old May 13, 2026 | 04:23 PM
cetialpha5's Avatar
It's not a recall, it's an extended 25 year warranty in the US. So yes, you'd be covered under the extended warranty. There was no recall on the SBC.
Old Jun 21, 2026 | 01:17 AM
diyer247365's Avatar
E270cdi with OM647.961
Hi, I am getting the C2131 'pressure reservoir faulty' error on scanner and I get a 'service brake visit workshop' in dash. Can I just change pressure reservoir without changing the whole unit? Thanks
Old Jun 21, 2026 | 07:32 PM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Must use Xentry or aftermarket equivalent to disable the SBC unit prior to service and then to reactivate it after service.
Failure to disable and de-pressurize the reservoir can result in 70 Bar (>1000 psi) or more pressure being vented into your face. When reactivating, ensure brake pads reseated on the discs *before* putting the car into gear and using the accelerator. Might take one or two activations using the brake pedal to ensure pads are firmly on the disc.
If in the USA, let the dealer do it. They even washed my car after the service.
Old Jun 21, 2026 | 09:27 PM
