Instructions to remove the DPF?
My 2013 ML350 Bluetec is at 400 000 km. My AEM warranty is over and now, all of a sudden (great timing!), I'm getting multiple codes related to emission stuff (Nox sensors, the PM sensor and a temperature sensor). I'm throwing in the white towel and going with a full delete from Malone. I'll do all of the work myself. My only concern is the DPF...
Does anyone have the instructions on how to remove it? Do you remove it from the bottom of the car or the top? Both? I've never removed it before. Any help would be appreciated...I've searched the forums and haven't found anything...
Thank you in advance.
I'm over 2 years past the delete with absolutely zero regrets. My son runs a fleet of OTR trucks so I asked his advice ahead of doing the delete. He said they drive their trucks bone stock until the first hint of emissions problems then its straight pipe and tuner time. That's exactly what I did. I was eligible for the field measures but elected to just get it over with and do the delete. I'm currently sitting at 320,xxx km.
We have no emission testing in Ontario. I'm going with the stock delete tune. Maybe I should've went for stage 1 with more HP/Torque. I simply want the best fuel economy and I suppose the stock tune will be better on fuel since it produces less power (so it probably uses less fuel) than the stage 1.
Source = https://tunezilla.com/catalog/Merced...ecuAddOns=4173
Excellent Video!
I have a 2012 ML350 Bluetec with about 136k miles.
The emissions recalls have all been done and everything is currently working.
I am retired on social security and not able to pay thousands of dollars for emissions repairs so I will likely be deleting when the time comes.
Unfortunately we have mandatory emissions testing every year (on a dyno) so I will need to find a way to transfer the title to a state without inspections to get around the testing. I hope Malone ships to the USA!
DPF is just a filter, it will be filled with ash if the engine produces ash. If you delete the DPF without repairing the engine, you will still have an defective engine.
Deleting DPF is 99% a scam, as the "tuner" gets the money from the client and from selling the DPF.
