Transmission cooler split
Thanks, Tom. Based in UK
I've got the part on back order with Mercedes, but I'm not holding out any hope given the part is no longer being manufactured. I've called a few specialists across the UK and the issue we have is that this specific gearbox oil cooler was only ever used on this generation C43 AMG. So it wasn't a component on other W202s, or even other R129 SLs or W210 E-Class from that same time period. As a result, it's bloody difficult sourcing that part as so few of them ever existed.
What I'm planning on doing is, given the fact my leak isn't a major one yet, getting my mechanic to remove the part and then taking it to a local specialist who work on repairing car radiators / oil coolers. I can then connect the correct hoses which are still readily available from Mercedes. Otherwise, the only other option is to get an aftermarket one fitted. However, given the placement of the oil cooler you will likely need custom pipes fitted elsewhere underneath the body and braced. I'm trying to get everything as original OEM as possible, but if I can't get it fixed this'll likely be my only option.
Let me know if you have any better luck than me!
