S-Class (W222) 2014-2020
B82 Humidity / temperature sensor
Old Yesterday | 04:33 PM
MayorMcCheese's Avatar
Forums Most Modified W222
On my 2015 I was on Xentry earlier today and the sensor for B82 on the Xentry has a malfunction and needs replacing. Problem is I can’t access EPC (SSD Issue)
can someone help me identify this part number to what I’m looking for?
the (2) part numbers I was looking into was 0009052411 and 000905520 using chat GPT but after looking up those part numbers and them not matching my VIN I don’t trust GPTs responses
This problem started off with my ventilated driver seat never working and then dug deeper and here I am
my VIN is WDDUG8FB9FA191351
Old Yesterday | 05:23 PM
carlosinseattle's Avatar
Top Answer: 1
2001 S600 V12 Sold, 2011 Jaguar XFR Sold, 2017 S550 4-Matic, 2018 S63 AMG Sedan
Does this help you find the part numbers: https://lemon-manuals.la/Mercedes%20Benz/
trigital's Avatar
W213 All-terrain
A2229051300
but...as Xentry is a diagnosis system ( not only a Fault Code reader), you can click on the "Current" Fault code and then the "Continue" button from the bottom right corner. This way, you can follow step-by-step tests.
You can also use the blue upper right corner booklet to see schematics, pictures, etc.
Old Today | 09:51 AM
Hey guys.
Lemon Manual is awesome but after digging thru it for over an hour I could not find it.
I called 3 dealers asking them if they could check the EPC for component B82 which 2 dealers do not part share but was able to get 2218300872 when I look it up for my car sais it does not fit I’m going nuts here
my ventilated seat and my rear vents do not blow air or get cold that’s where this is coming from I reached out to Peter but my laptop was not working.
Old Today | 10:10 AM
trigital's Avatar
W213 All-terrain
Hey guys.
So you can't use Xentry?
