W204 3.0 Petrol Intermittent No Crank + Fuel Gauge Drops During
Old Today | 05:42 PM
gmmccfn's Avatar
Hi everyone,
I have a Mercedes-Benz W204 C-Class (2008, 3.0 petrol engine) and I’m experiencing an intermittent starting issue that I can’t clearly diagnose.
The issue happens occasionally:
  • I turn the key to start the car
  • Sometimes I only get a single “click” or the engine turns just a fraction (about one rotation) and then stops
  • On the second attempt, the car starts normally without any problems
This does not happen every time, only occasionally (it has happened twice within a few days).
Another important symptom:
  • During one of the failed start attempts, the fuel gauge suddenly dropped to empty and the low fuel warning light came on
  • After the engine started, the fuel gauge returned to normal within a few seconds
The battery is new (2–3 weeks old).
Once the car starts, it runs perfectly with no warning lights or drivability issues.
Possible causes I’ve seen mentioned include:
  • ground/earth strap issue
  • battery terminal connection
  • starter relay or SAM module
  • starter motor beginning to fail
Has anyone experienced the same symptoms on a W204 3.0 petrol?
What was the actual cause in your case?
Thanks in advance.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
