Replacing main battery
Old May 30, 2026 | 11:54 PM
LumpyCam's Avatar
2017 E43 AMG Wagon - Japan Import
Been having trouble with my dash cam shutting off when parked and upon investigation, my main battery is showing a low voltage with a meter, 11.5v when parked.
The screen has also 3 or 4 times a week been showing the "start engine, see operators manual" warning/
So i'm going to purchase a new battery next week.
Been trying to find info on whether it needs to be coded or reset when replaced, does it?
I have a Launch X431 Elite 2.0 if it needs coding, where do I find what section/listed under?
2017 E43 AMG Japanese wagon
Old May 31, 2026 | 11:26 AM
taphil's Avatar
2024 GLE63s, 2021 E63s, 2018 GLC43
Just swap batteries and that's it.
Old May 31, 2026 | 12:22 PM
streborx's Avatar
Top Answer: 1
G550
If your battery is OE, you've done well to get 9 years of life from it. I replaced my '19 G550's battery at 42 months. No special procedure was required. My replacement battery was a quality aftermarket brand, not MB genuine OE. It's still fine after 42 months.
Old May 31, 2026 | 12:54 PM
figuwx's Avatar
2018 AMG E63s Ed1
No special anything for e63s battery replacement.
Of note, our cars are H8 not H7 like most online sources say.
I posted this thread as I just replaced my OEM battery
https://mbworld.org/forums/w213-amg/925001-tech-w213-e63s-battery.html
Old Jun 1, 2026 | 01:31 PM
OBP's Avatar
OBP
E63 S AMG, CLS550 4matic, C63 Ed 507, Volvo XC90 T8s
I did the battery swap a few months ago - 2021 E63. Dealer parts store suggested use an H7 and I got an 850 CCA Interstate Battery from Costco. Worked just fine though I did 1) trickle charge to max before install 2) did a reset of the battery monitor with a Foxwell scanner. Smooth process no issues. And all small electrical gremlins I seemed to be having simply went away.
Old Jun 20, 2026 | 05:37 AM
alan.note's Avatar
E43 Estate
I am about to do the same.
I am told new battery needs to be registered.
I am looking to get this one , Bosch LN4 ST Hightec AGM 80Ah 800CCA Starting Battery 0 092 S67 053
I have the same car as yours , Japan import to Sydney
Old Jun 20, 2026 | 11:16 AM
streborx's Avatar
Top Answer: 1
G550
My G550's battery did not require registration, but things are always changing. You could call a MB dealer, ask for a new battery quote + installation, and ask "does that include registration?", and see what he says.
