S-Class (W222) 2014-2020
New to forum
Old Jun 7, 2026 | 10:30 AM
Nitrouspaul's Avatar
2014 s550
New to forum
Hi, just wanted to introduce myself. I’m new to the forum. I recently bought a 2014 low mileage S550 and coming from a BMW. I understand I’ve got a new learning curve to go through so I might be chiming in here now and again asking for advice, but to start off with my first question, is there anything I can do to this car preventative maintenance wise to get ahead of any of the common problems that might occur it only has 19,000 miles on it and is very clean car but I do know that there is the common oil wicking from the cam sensor harnesses and perhaps I should disconnect the oil pump harness to keep the oil pressure high to prevent any internal engine problems such as bore scoring. so far this is what I’ve been able to find on the YouTube channels Common problems. If there’s anything else I should know about I’d appreciate the experience from the members in this group, I live in Ontario Canada, and have a full shop in my garage with 2 lifts so i will be taking ownership with a hands on approach to maintenance.
Old Jun 7, 2026 | 10:33 AM
W205C43PFL's Avatar
Originally Posted by Nitrouspaul
Hi, just wanted to introduce myself. I’m new to the forum. I recently bought a 2014 low mileage S550 and coming from a BMW. I understand I’ve got a new learning curve to go through so I might be chiming in here now and again asking for advice, but to start off with my first question, is there anything I can do to this car preventative maintenance wise to get ahead of any of the common problems that might occur it only has 19,000 miles on it and is very clean car but I do know that there is the common oil wicking from the cam sensor harnesses and perhaps I should disconnect the oil pump harness to keep the oil pressure high to prevent any 8nternal engine problems such as bore scoring. so far this is what I’ve been able to find on the YouTube channels Common problems. If there’s anything else I should know about I’d appreciate the experience from the members in this group, I live in Ontario Canada, and have a full shop in my garage with 2 lifts somi will be tak8ng ownership with a hands on approach to maintenance.
I am not sure if the oil pump solenoid unplug actually helps with bore scoring, you are referring to this thread right? https://mbworld.org/forums/w212-amg/...solenoids.html
You have a M278 right? Is the oil pump solenoid even applicable to that engine?
For the harness pigtails, you could consider this:
Amazon Amazon
Old Jun 7, 2026 | 10:35 AM
W205C43PFL's Avatar
Oops I posted the wrong amazon link, it was this one (CAD)
Amazon Amazon
Old Jun 7, 2026 | 02:38 PM
JohnLane's Avatar
222 S-65
OP get your friendly service advisor at the local MB dealer to present you with a VMI for your car. It will list all the work performed by Mercedes, all campaigns performed, all options the car is equipped with and other fun things like radio codes.
Low miles on your 2014. You have a shop so unless they have been done previously fresh fluids are top of the list. The transmission lacking a dipstick has and continues to be a head scratcher for me but once you've done that service it is easy. When you have the pan off weld a bung to it for a drain plug so you can quickly and easily do a drain and fill of transmission fluid. This negates the need for pulling the pan to put the plastic guy back in place every time the fluid is dumped.
Rear-driver? If so there is a good chance it is equipped with Magic Body Control. Good stuff. Another fluid and filter to change.
Enjoy your car!
Old Jun 7, 2026 | 03:36 PM
2014 s550
i do have majic body control. Oil was changed but not sure about others. I have a problem already for this forum.
yesterday battery was totally flat. Installed another one. Today battery was comletly flat.
only change is i parked in garage with ds window down and didnt lock the car.i am reading that this can kill battery overnight. This is stupid. Anyway to bypass?
i will charge battery today and close window and lock door and reassess in the morning to confirm for sure. Anyone ever hear of this?
Old Jun 7, 2026 | 03:38 PM
2014 s550
Yup thats was my read.
Old Jun 7, 2026 | 03:42 PM
W205C43PFL's Avatar
Do you mean by charge as in using a battery maintainer like ctek or do you mean driving it out?
Old Jun 8, 2026 | 08:07 AM
2014 s550
it will be fully charged overnight. It is now fully charged. I am going to test with a multimeter this morning for parasitic draw on the ground side. I will lock the doors roll up the windows and dummy latch the trunk. Then i will wait an hr for the modules to go to sleep and report back .
if i do find a draw i hear the seat modules are a culprit is that so?
Old Jun 8, 2026 | 08:38 AM
W205C43PFL's Avatar
That was a thing on other MB models not too sure if also a thing on W222.
Old Jun 8, 2026 | 08:49 AM
cdmotor1's Avatar
2019 Mercedes Benz S560 4Matic
Hold on….are you saying that not locking the car can cause battery drain? I have a 2019 S560 4Matic, owned for a few years, park in my secure garage overnight and never lock the car in the garage. No battery issues yet. What does not locking the car have anything to do with it?
Old Jun 8, 2026 | 08:52 AM
W205C43PFL's Avatar
They thought the car never enters sleep when you don't lock the doors but it isn't exactly true. The main thing is make sure keys are not in the detection zone so the car goes to sleep.
Old Jun 8, 2026 | 08:59 AM
cdmotor1's Avatar
I see. Thank you for the additional information.
Old Jun 8, 2026 | 02:08 PM
W205C43PFL's Avatar
You're most welcome, double press the lock button to disable the key (do it for the spare key as well) so the car can't detect the key, also prevent relay attacks too.
Old Jun 8, 2026 | 05:51 PM
JohnLane's Avatar
222 S-65
Or park it in a secure Faraday Cage as I do with mine.
Old Jun 8, 2026 | 06:57 PM
NbyNW's Avatar
Veteran: Navy
Various
Same here, I have a Faraday box for keys.
Old Jun 8, 2026 | 08:24 PM
W205C43PFL's Avatar
Ditto.
Old Jun 8, 2026 | 11:49 PM
BenzV12's Avatar
W212 FL
Congrats, that's a great pick up given its mileage . M278s are one of my fave engines but those are not without faults either . I have heard leaking cam magnets but yours is extremely low mileage for it to happen I guess . Anyway, let's not forget it's more than 10 years old
Happy Driving
Old Jun 9, 2026 | 10:15 AM
2014 s550
Update.
the bluetooth transmitter for relaying ecuminformation to the otofix scantool i have was left in overnight.
It was drawing a load of .428 amps
i cant indertsand how this small drain could kill a oddessy agm 970 cca battery and the mercedes varta battery overnight as both are top tier.
But it did. My draw at rest with everying off (bluetooth removed from diagnostic port) doors closed locked is .07 amps now. A bit high as factory calls for .03 to .05 it will draw down battery voltage by .04 volts every 4 hrs.i am testing the battery volts every 4 hrs now for a 24 hr period to see if it stops because my battery is now at 12.55 volts down from 12.78. Knowing how sensistive these cars are to battery voltage i get scared thinking if i go out of town for a week and no tender what will i end up coming back too.
just went out to garage and after another 8 hrs the battery has settled in at 12.55 volts.
i am going to do this 24 hr experiment again with the window down and the doors unlocked tmrw and see if results are the same drawdown or worse as maybe this will,leave something on from sleeping and exasperate the draw. I will report again soon
Old Jun 9, 2026 | 10:59 AM
JohnLane's Avatar
222 S-65
.43amp as a draw will wipe out any battery. .02 to .08 amp perfectly normal. MB wants the car on a maintainer if it is going to sit a week or longer.
Old Yesterday | 06:22 PM
Z06Life's Avatar
2020 S560 4matic. 2017 Z06 convertible.
This right here. I always double. I also keep all keys in a nice little Faraday cage box.
Old Yesterday | 07:08 PM
W205C43PFL's Avatar
Double protection : )
