Cam Position Sensor DIY
Old Jun 8, 2026 | 11:53 PM
E63SAMG2014's Avatar
2014 E63 / 2017 CLS 63 / 2015 G63
Any tips or feedbacks on owners who changed or regularly check on their CPS?
Old Jun 9, 2026 | 04:55 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
check for oil in CPS connector.
Replace new with disposable pigtail extension.
Disconnect batteries then check ECU connectors for engine oil - Reset fault codes.
Check VVT Solenoids if you care to.
Old Jun 9, 2026 | 02:10 PM
battery must be disconnected before checking for ecu?
Old Jun 9, 2026 | 07:10 PM
disconnect or not...
I would power down the chassis or every ECU partners are going to miss it across CAN-bus.
You can try without disconnecting batteries, scan afterwards to see what pans out....
Many CAN Modules are powered 24x7 in low power mode, not powerless.
This is how ECU faults sensors disconnected regardless it was off.
