Add a amp
1. Anyone know of a plug and play t-harness to add a sub? I searched and found some for pulling all speaker outputs into a DSP. I just want to t off the outs that would provide a full range bass signal. I guess a complete harness would work if I find a good wiring diagram and I can rewire it but that’s problem 2.
2. Can someone share the wiring diagram that covers the Amp?
main goal is no sloppy splices but the ability to just undo a connector or 2 and be back to stock.
I have a JL audio fix-86 that I can use to sum, level, and create the sub output. Also have an audio control LOC.
I will message my installer now and ask him how he would add just a sub. I know that the the factory subwoofer is located in the trunk, behind the back seat.
I think your best bet would be to splice the speaker cables at the sub and use your FiX-86 to convert the high level signal to low level. Forget the Audio Control, that's not as good as the FiX.
I'll get back to you...
So I guess the Audio Control is the way to go.
Anyone have the wiring diagram?
I own a car audio speaker company, so I'm using my own speakers. This will be a sound quality competition/demo vehicle for my business, and my daily driver. Will post a full build log when it's complete, but that won't be for a few more weeks at least.
We are using a 1" tweeter and 3" midrange in the front dash corners / A pillars. And a 6x9" midbass will go in the factory midbass locations in the front firewall. A pair of ScanSpeak Revelator 13" subs are going in a sealed box in the tire well.
So that's 6 speakers up front, and 2 subs. 8 drivers total.
For source, we're putting in an RME ADI-2 Pro Fs-R home audio DAC into the ashtray location. That will be the main source for competition since it's cleaner than using the car's source. The NAV-TV will be there in case I want to use the CarPlay or any of the car sources.
A Brax DSP and a pair of Brax MX4 Pro amplifiers are going in. 300W x 4 from each amp, so that's 2400 watts in total.
can’t wait to see the post when it’s done
Passenger side midbass, modified to fit a 6x9" speaker.
Wow. Beautiful work! Is that behind the glove box?
