M276 Cold Start Stumble
An internet search returns a leaky fuel injector could be the culprit.
Anyone have had this experience before?
https://mbworld.org/forums/e-class-w...ong-crank.html
? How is the coolant sensor? All random questions on things that may or may not be related.
Going to give the two a call (order of call does not have any significance) : )
@CaliBenzDriver
@S-Prihadi
Good call on linking fuel to this stumble. Surya knows the expected rail pressure on the 3.0 TT. 1740.Psi meets minimum specs. We've seen bad rail sensor... I don't think this is a case for it.
What is your current mileage... 90 to 120k.Mi ??
May be time for a set of new Lambdas based on oil consumption + 100k Mileage...
-- The one thing I'd be interested in is your Longterm Fuel Trims at warm idle LTFT: 1+2... lean??
-- Look at your live misfire counts to help pick your weak cyl !
-- How old is your ignition tune-up: done or coming ??
-- Before committing the time to measure real cyl. compressions ... pls read your 4X camshaft correction factors.
--> I would not be surprised by a lean trim forcing random cold misfires. Let's confirm LTFT's corrections first.
Many items can contribute to misfire including low voltage. A missed combustion is a missed /weak contribution. We dont want that!
Right now there is no parts necessary until tested bad. Don't rush to coils & Injectors for random cold stumbling.
Can you pls record your 30sec cold start sequence to hear fast idles.
What other steps are you considering doing ?
One thing we can say is your engine is going to have more power once it's running well.
### Clean both of your MAF + MAP sensors.
No misfires. 65k miles.
Rail pressure 119 bar and in-tank fuel pump (LPFP) at 75 psi at idle (updated using Xentry). I did wait until full operating temp (>176 F) to take the measurements.
Main battery SOH 99% and SOC 100%, but that was after running the engine a while. Aux batter SOH 100% and SOC 100%. I will check the main battery again in the morning before starting the car. I do have an ultrasonic rodent repeller running all the time off of the main battery.
plugs probably have about 20k to 25k on them.
will be keeping an eye on things.
65kMi is an early mileage...
Lambdas should be ok.
> Preliminary answers rule out:
ok good battery voltage
ok recent ignition plugs
ok fuel pressure delivery
> Remainings are:
2x warm idle Fuel Trims: LTFT 1+2
(4x Camshaft positioning correction factors)
> Miscellaneous:
Clean up your oily MAF + MAP (3.0 has both)
I will record that startup sound tomorrow morning and post it. The “stumble” can be heard in the exhaust. The exhaust on the SL400 has always been a little throaty compared to my C350. Like I said, no DTCs and the misfire count across all cylinders is zero.
I double-checked my records and my plugs have about 18k miles on them.
isn't "the stumbling" in synch with the ECU ajusting the throttle lower as engine warm up ??
Right after cold start up there are many rapid Rpm transitions.
(I wouldn't even consider the single throttle plate being dirty).
You don't have a leaking injector nor a bad ignition.
This is consistent with unmetered air inlet.
Check your charge air inlet ducts are sealed.
camshafts positionings
Intake B1; B2: = (32.5°) ; (35.0°) .... 2.5°!!
Exhaust B; B2 = (-23.3°) ; (-22.6°).... 0.7°
Your intake cam positions are significantly apart. I'm not sure if this is phaser or chain and unlikely shifted reluctor. It's still within specs so not calling a fault while ECU is applying correction.
This 2.5° timing difference can upset your fuel trims.
I will try to figure something out.In the mean time, the video shows very slight puffs of smoke (or water vapor) whenever you hear the stumble. It happens three or four times. Very interesting….
- Exhaust sounds excellent
- I failed to see any smoke
- Startup idle ramps down quickly... great!
Can you capture the sound from the engine itself when acting up.
Is this cold only or warm also?
There are no misfire codes or counts. Coolant level is good.
The puffs of smoke come out of either side exhaust. I have not watch for the same coming out of both sides at the same time. I will try that next. The SL R231 exhaust has two H style cross-over pipes, one in the front and one towards the back.That may or may not tell me if the cause is coming from one bank or the other or both. This is quite the mystery. If it continues, however, I may take the car in to my local Mercedes dealer.
Cold start only. The smoke or vapor is very brief and dissipates immediately.
Get the dealer to check your intake phasers are ok or offset at 53°.
Before starting the car today, I did open the air boxes and checked the filters. I also vacuumed the filters (which were virtually new) and any debris on the pre-filter side of the air box. I did notice that the seal on the driver side filter was twisted a little bit and I fixed that. In the process, I disconnected and reconnected what I believe are the intake air temperature sensors. Started up with no detectable “hiccups”. Also, I had the ignition on for probably a minute or so before starting the engine to detect any misfires (fault counts) — there were none. The verification will be tomorrow.
