E-Class (W214) 2024 -
Software upgrade debacle
Old Jun 15, 2026 | 11:45 AM
regor60's Avatar
06 E55 Black
I took the car in to fix a rattle and I was informed that a software upgrade was required I believe due to the current recall.
The factory installed head unit wouldn't take the software download so Germany said replace the head unit.
The head unit was replaced. The software download was delayed due to a final module not loading properly. That eventually worked.
In the course of finalizing everything the technician entered the wrong odometer reading. Odometer inputs are locked down and not permitted to be corrected by the technician and must be referred to Germany.
Germany is unable or refuses to fix the odometer reading and suggests a new head unit be ordered. Presumably they don't want to be on the hook for any odometer rollback issues.
Once the new head unit is installed the process will repeat. I haven't heard back on how long it'll take to get a new head unit in.
Old Jun 15, 2026 | 04:45 PM
W205C43PFL's Avatar
Sigh, as for replacing the head unit you probably know already that if a software brick the head unit (which it did on the original unit), it is easier to replace it with working software than getting the dealership to try to fix it, Germany has the low level software tools to fix the broken/bricked unit.
How did they mess up the odometer, imagine them doing a bank transfer and entering an additional digit, don't they verify before pressing ok?
Old Jun 16, 2026 | 06:19 AM
WagonAllTerrain's Avatar
2026 E53 Wagon
Ugh that sucks. Sorry.
Curious - where was your rattle and what was the fix from the dealership?
Old Jun 16, 2026 | 01:44 PM
regor60's Avatar
06 E55 Black
Yes I couldn't believe that there isn't apparently some kind of red light flashing to double check the entry of the odometer before it is locked in because in effect it bricks the unit absent Germany being willing to adjust and send the files which apparently they're not willing to do.
And of course I'm not happy that they're dismantling the dash assembly twice now and I emphasized my concern that this dismantle and install process doesn't itself introduce noises and that they make sure every clip is secure and so forth.
The original noise to be addressed was a vibration in the headliner above the rear window, which the service advisor said they were addressing by installing insulation in that area
I'm also going to verify before I drive off that the odometer reading is within a reasonable mileage reflective of test driving of the car when I put it in the shop .
Old Jun 16, 2026 | 02:31 PM
W205C43PFL's Avatar
Hope it works out OP.
Old Jun 16, 2026 | 03:46 PM
McNeo's Avatar
W214 E350
Head unit replacement was somewhat common; I know a few of us had it done. What sucks for you is the slip-up of the technician fat-fingering by entering the wrong ODO reading.
Hope they gave you a decent loaner in the meantime!
