RF air strut/corner won't lower. Stuck fully extended
I was in the process of adjusting my ride height using adjustable links because the right front corner always sat a little higher than the leff. It wasn't even visually noticeable but I knew it & had to "fix it".
Not sure how it happened, might of turned the ignition switch on to check the voltages of the left sensor while the right sensor was either disconnected or the leveling arm in the wrong position regardless at some point the right front strut fully inflated lifting the RF to the max.
I can't get the RF to lower, it's stuck at 80mm. I tried bleeding the air by disconnecting the air line, using a 9v to activate the solenoid, still nothing.
Bought a bidirectional scanner, to raise/lower each corner but still can't get it to lower to normal ride height. It's showing the RF strut pressure around 1 bar but won't go any lower, assuming because that's atmospheric?
With no pressure in that air strut how is it possible the RF corner isn't sitting on the wheel?
What could possibly be holding it in the extended position? Everything was fine before I touched it.
Just disconnected the upper & lower strut bolts. Tried to compress the strut itself with the jack & it won't move.
There has to be air still stuck in the strut despite what the scan to says. Now the question is, how do I remove it if I can't deflate it? Prefer not to destroy it
Failed sensor reading one Bar while pressure is actually much higher along with a potentially failed solenoid. This points to pins bent/broken in the connector. Difficult to see but a phone camera helps. If using Xentry, it should show "open circuit".
Our buddy HemiAlex had a problem similar to yours and the source was a bent pin that failed to enter the socket of the connector.
After some research it sounds like scan tools take the pressure reading in the air bag, rather the air pressure going to it. Which would explain my situation. Zero pressure in the line and a faulty solenoid keeping the air in the strut.
I've tested this with a 9v battery, trying to activate the solenoid. I can hear it clicking but it won't release the air pressure.
I'm assuming you probably can't just replace the bad solenoid and requires a new air strut.
Any su
https://mbworld.org/forums/w211-amg/...messed-up.html
Also explains my inability to level the front no matter how many adjustments I made. The right front would always sit higher. Which makes sense if it wasn't releasing any air.
On a side note I bought a Creader Elite v3BN bidirectional scan tool for around $170. Seems to be working pretty well. It'll allow me to adjust ride height & was finally able to turn off the tpms sensor when I switch between summer/winter tires.
Mines came programed with Mercedes but you can download manufacturer specific programs for $30-50.
