A/C not blowing cold air, no sound from compressor?
Old Jun 19, 2026 | 07:53 AM
leungsta's Avatar
C63 AMG Coupe, BMW 335xi Frozen Silver
My A/C stopped blowing cold air in my E63s S212. After a scan, the only error code showing related to A/C was 912749 (air quality sensor malfunction).
What I’ve done so far:
- Fuses have been checked
- Refrigerant levels were checked (originally too much Freon so I removed some back to normal levels)
- Changed the air quality sensor
I do not hear the compressor at all when A/C is on.
Hoping the forum gods can point me in the right direction as I do not want to go to the dealer for this.
Old Today | 12:56 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
A/C basic troubleshooting
Can you read the A/C pressure sensor from AAC Module ??
Can you see compressor shaft spinning?
Not the outside part, the inside part.
Compressor clutch solenoids go bad routinely. Clutch does not spin at all (beside the PWM Valve).
By doing this DIY you get to replace only the bad parts for peanuts.
