2019 C300 Coolant Leaking Issues
Old Jun 20, 2026 | 03:56 PM
juanalzate0110's Avatar
2019 Mercedes Benz C300
Question 2019 C300 Coolant Leaking Issues
Hi everyone,
2019 C300 here, found some coolant on the floor of my garage the other day after driving the car around. Got home, popped the hood, took the plastic engine cover off, and notice the hose coming from the reservoir into the engine was leaking. Seems to be leaking around that connector that I'm pointing to here in the photo.
Didn't want to address it right then and there as the engine was really hot and wasn't sure if this system is pressurized at this point or not.
All that being said, any ideas what the fix here might be? Any parts I might need to replace? Any suggestions for anything here? Thanks a lot.
Old Jun 21, 2026 | 04:28 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
one time use
Originally Posted by juanalzate0110
Hi everyone,
the coolant hose connector must use an O-Ring seal, right?
Buy a few spares and replace one when cold.
Each time a coolant connector is disturbed, seal must be replaced new because it rolls over itself during insertion. Use silicon lube to help.
These are the ultimate "one time use" parts like the aluminum bolts that snap at 5NM.
Old Jun 21, 2026 | 06:00 PM
TimC300's Avatar
What is the part # stamped on the hose you are pointing to?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
