Leaking Injector + Coilpack causing combustion when car is off
Running theory is that a leaky injector + faulty coilpack fired when the electronics were woken up upon unlocking. In my case, this has now caused a decent amount of oil to pump out of the dipstick channel after driving. No suction on oil cap while running (no pcv whistle either) and doesn’t leak while stationary.
I just recently had a vacuum pump hose replaced (which was causing oil to pump out of the dipstick) so wondering if its that. Any input on either of these issues would be greatly appreciated!
Will update when everything is taken apart. Thanks!
Hopefully not on your watch.
Is it a rod bearing knock ?
or a low oil pressure startup rattle ?
or a HPFP flat roller knock ?
Hopefully every things go according to plans.
