Long Term Fuel Trim Question
Right now you have two 4-Cyl. banks, dragging each other mad out of balance. Take it easy with high loads. This freaks out ECU timings.
Your LTF1 is calling for a lot MORE fuel.
Your single fuel rail is pressurized by two HPFP both supplied by one smart tank pump. This is a return less fuel system -- Very likely ok here: unbalanced.
Nothing wrong with your ignition.
Use your scanner to read:
tank pump pressure
fuel rail high pressure
both LTFT 1+2 at warm idle.
Basically your O2 was/is correct !!
Your Bk1 is way too LEAN... ie. it has too much air or not enough fuel.
Any other misc engine issues or CAN faults that may be overlooked here ??
You're gonna need to figure this one out soon...
maybe GDI injectors are plugged up by heavy oil contamination ??
How many Miles: low/high ?
How much oil burns through: more than 1Qt per ??
How is this engine used ?
How about leaking wategake or cracked turbo manifold?
what were previous maintenance/repairs done?
The sooner you can zip to the finish line by discovering the obvious cause, the cheaper the fix will be.
tank pump pressure
No pressure gauge needed.
The ECU has control over rail pressue through the pump valves. It's helping compensate for your lean trim a little.
> Your summary reads :
- lean engine Bank1 has rich LTFT1
- fuel pressures H/L: ok
- no ignition misfires: lean!
- no bad injector: no misfire!
- Lambda b1: new
I asked for maintenance record...
-- Did someone had a chance to messup intake seals recently??
-- How old is the PCV system : 110kMi?
-- Did MAF + MAP sensors get cleaned up a little?
At least this has a chance to be a cheap repair for now. Regardless your mileage is due for fuel delivery soon 3x fuel pumps + filter. After this Lean is fixed!
- Lambda b1: new
Other than oil and air filter changes,
the only engine work that has been done has been done after this started.
Since this started I have had :
the plugs,
coolant lines,
O2 sensors and
the cam sensors replaced.
I think I may change the vacuum pump valve this weekend.
This helps the process of elimination.
Clean the MAF + MAP sensors then clear related faults.
