SL/R129: NewB here...Intro and in need of help
Got a few questions for you experienced guys. When I first purchased the car, the previous owner disclosed all possible faults. One of which is the soft top operation. The top is currently in the closed position. When operating the switch that activates the top, it seems to be in good working order when I push it forward, which I assume is to close the top. The motor engages and the mechanism seem to be moving. Its already in the closed position so movement is at a minimal. However, when I pull on the switch to lower the top, all I get is a blinking light with no slight movements of the mechanism. I checked the pump in the trunk and the fluid is full. The PO said this all started when the car's battery was drained and he had to jump start the car. The battery now seems to be fully charged. I tried opening the top while the engine is running and same result. He also said that two other problems came immediately after jump starting the car, the ABS and Check Engine Lights are on. On a side problem, the passenger door lock doesnt lock when the remote transmitter is pressed. All other locks work.
I hope that someone can shed some light in this matter, or at least point me to a starting point and direction. If the switch operates the top mechanism to close, then should I rule out that the top control unit as a culprit? Thanks in advance everyone.
Took it to the dealer who confirmed control unit to be replaced at it cost £1000
(it was 'only' £1k because i found out they could return the removed soft top unit - otherwise they wanted £2.5k!!!).I really hope it isn't the control unit!!!! try what firstkill said... fingers crossed!
Whats next? He he he...time for some fun in the sun with the top down.
Thanks again and I hope this thread will serve someone well in future reference.
