SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 1st Post 2000 SL needs help
Old Sep 20, 2005 | 02:52 AM
Adairs's Avatar
2000 SL Roadster
Engine 113.961 Chassis 129.068
New enthusiast here that can't find an answer to my problem with the search function.
Having some blower motor problems with this vehicle. Was very much hoping that this was a more common problem & had a cheap solution. I found two post where people did indeed have the same problem, but nobody ever gave them any feedback. Both post went unanswered.
It sounds as if the motor is hitting the housing under certain conditions.
What do most of you use for Spark Plugs? I can't bear the thought of using Bosch Platinums.
Who are the best non-dealer mechanics to see in my area of Dallas TX??
Old Sep 23, 2005 | 03:57 AM
Adairs's Avatar
Nobody in Dallas can even recommend a good mechanic?
How is Louden or EuroImports??
I will try to contribute back in hopes of improving on the wealth of information garnered so far:
Parts ordered from Importec Online:
sales@importecparts.com
2000 SL Roadster
VIN # WDBFA68F6YF19****
AC Blower Housing (Local Mechanic Repair)
Brake Rotors Front N1000-88938 $98.95 each (2)
Brake Pads Front N1010-132121 Jurid $89.50
Brake Pads Rear N1010-107048 Jurid $55.94
Brake Sensors N1030-26105 $01.92
Spark Plugs
(16 total required)
NGK Iridium BKR5EIVX-11 (Gap 0.0032)
Denso IX-16
O2 Sensors, Downstream after Catalyst (2 required)
C5010-68090 Bosch $108.68 (2)
Filters:Fuel Filter
E1000-87553 Bosch $28.02
(There are several more expensive options here from Mahle , Mann or Knecht)
Transmission Filter:J5000-56367 $7.86
Steering DamperM4000-36163 $29.59
Door Check Straps O3010-35425 $26.41 each (2)
Evaporator (Vent Valve) E2014-127034 $45.18
Hood Liner Pad O2040-74534 $70.35
Total $985.38
Fluid Maintenance List:Radiator Flush,Transmission Flush,,Power Steering Flush,Brake Flush,Fuel Injector Service,AC 134 Re-Charge
Used to the Club Lexus Forum were we seldom need help but when you do there is good advice.
Primary ride is a 94 LS 400 w 197,000 miles. Are there Techs here our does everybody pat each other on the back & say I have one too??
Old Sep 24, 2005 | 01:49 AM
sl500_dallas's Avatar
2006 SL500
The best Mercedes mechanic that I have ever found is Auto Hans in Addison.
www.autohans.com
It is German owned and operated. Alex Green is the mechanic that you will most likely deal with. He is definitely German, no small talk or anything, but I would bet that he can build an SL from scratch.
I have been using them for almost 10 years now and I have never had to go back a second time once they said that my car was fixed.
Old Sep 25, 2005 | 12:51 AM
MB-Dude's Avatar
'96 SL600, '05 S55 AMG, '06 C230
WHOA, Adairs
You assume everyone is from Dallas. I'm from the Bay Area of California and can recommend a couple good mechs here... but do you really want to drive that far? Don't know anyone in Dallas; suspect most others do not either.
As for spark plugs, there are a couple discussions going on in the Tech Talk section. Check 'em out and join in.
