SL/R129: False Fuel Reading
What would cause the gauge to suddenly malfunction? Im never sure as to if it is truly near empty with needle at warning area.
2) It could be the fuel sensor mechanism. Mine was replaced under the extended Starmark warrantee.
The fuel gage in my car shows 1/2 one day and 1/4 the next and then back to 1/2....
As long as at the end it works well..i.e: when you're near emty..
Work out your consumption and fill up at the right time..
Unless you need to change the sensor which is costly...
