SL/R129: Leather Conditioner
Which model of the Polti do you have or recommend?
It seems to me that steam would cause the leather to dry out rather than moisten it. Is there any drying out in long term use? Thanks for the advice.
We looked up Polti on the net and it looks great for cleaning carpets, stoves and windows. Now my wife wants one.
Herb
It won't dry your leather out because it leaves moisture on the surface of your leather... it doesn't 'cook' the surface if that's what you are concerned about. It works two ways, by forcing moisture into the surface with high 'dry' steam pressure, and the heat of the steam cleans up brilliantly...
You'll find that the surface is left wet, rather than dry. You have to use terry cloth on the attachment so you aren't applying the steam direct.... don't use the attachment that you use to clean the stove with or you'll definitely ruin your leather!
The model I bought is the Vaporetto 2300 and its fantastic and its great for cleaning the house as well... which is the real reason I bought it!
Now if only I knew this much about how a V8 works....
