SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: cracks in suspension
Old Mar 19, 2006 | 09:18 PM
rellik's Avatar
mercedes
i have metal fatigue in my front left and right suspension
noiticed it while changing my cabin air filter
the part number on the cracked bit is: 124 320 04 73
anyone have any opinions/suggestions
thanks
Hersh Singh
excuse the dirty engine bay pictures
left shock:
right shock:
Old Mar 19, 2006 | 09:55 PM
HLG600's Avatar
2009 SL63 AMG
My suggestion would be to repair it. Since this piece is already cracked, its structual integrity is shot, meaning that it will worsen and the crack will expand. Better fix it before it causes more trouble.
HLG
Old Mar 19, 2006 | 10:13 PM
rellik's Avatar
mercedes
is that part seperate from the entire shock? or
will i have to replace the entire shock assembly
if the second, it may be a good reason to upgrade to hi-perf shocks and springs
Old Mar 19, 2006 | 11:52 PM
pcviewer's Avatar
2006 Aston Martin Vantage
This thread will be very useful:
https://mbworld.org/forums/sl-class-r129/357-tip-you-higher-mileage-129-people.html
Has instructions on what needs to be done (DIY) and what may happen if you do not change it.
Old Mar 20, 2006 | 12:30 AM
Bigdot's Avatar
some
its just the shock mount, i had to do mine when i first got the car, then later i had to change out the whole suspention.
mark
Old Mar 20, 2006 | 08:46 PM
rellik's Avatar
mercedes
who are good spring manufacturer recommendations also?
thanks
Old Mar 20, 2006 | 10:48 PM
Bigdot's Avatar
some
thanks
go Bilistine! get the sport/hd or the like race ones.. they are awsome! thats what i replaced mine with (4)
mark
Old Mar 21, 2006 | 02:06 AM
dafi129's Avatar
SL 55 , Infinity FX37, Aprilia Caponord Rally
Those are the top shock mounts.
If they go,your shocks will go through your bonnet...It has happened before.
Change them now if you can..they are not very expensive.....
Old Mar 21, 2006 | 04:31 AM
agentMurdoc's Avatar
yeah just replace them. You could do it yourself, I think they run about 80ish dollars from the dealership.
Old Mar 21, 2006 | 08:57 AM
rellik's Avatar
mercedes
took it in to my independant mech, i had some other bigger work i had to get done so i tacked this onto that
thanks for all of your help
Old Mar 31, 2006 | 09:04 AM
rellik's Avatar
mercedes
fixed, just needed new strut top mounts
Old Mar 31, 2006 | 02:18 PM
SL BRABUS's Avatar
2 SL with every Brabus mods available & Class A competition sound system
what you waiting for.. ....you on a roll here.... .... just joking......
Old Mar 31, 2006 | 08:10 PM
rellik's Avatar
mercedes
nah , just updating some threads
hopefully someone can use the info as well
