SL/R129: remote needed
That's why you have to go to the dealer for a replacement. Anyway, they're not to expensive, mine cost around 50GBP.
Lea
Or send your current IR to an electronics eng for repair. If it's eating batteries I would suspect some type of corrosion causing additional current drain, which could be cleaned.
Lea
The second issue is the transmission that locks/unlocks the doors. As far as I know, most systems use a “rolling code” algorithm that changes the “key” with each use. That is why there is a “synchronization process” in the owner’s manual. If the fob and the controller loose track of the current “key” (you change the battery for example), you must go through the process to “resync”. There are a number of patented algorithms that do this out there. I would suspect (but I don’t; know for sure), that any fob designed for your year would work to open/close the locks after “resync”, but (see above), may not start the car.
The problem you are experiencing with you fob definitely sounds like corrosion. Conductive salts in the wash water are shunting current from the battery and causing the drain. If you’re really feeling lucky, you can try the following. I have used it on key fobs, cell phones, garage remotes, and various other sundry electronic items that have been washed or otherwise exposed to water. I want to emphasize that doing this may render your key fob COMPLETELY INOPERABLE, so consider this carefully. If you do want to try, do this: Remove the battery. Wash you key fob thoroughly in 70% isopropyl alcohol, A.K.A., rubbing alcohol (from you local drug store/pharmacy/chemist). Be sure you plenty of I.P.A (e.g., really soak it). Leave the battery out and place the key in a warm dry place for 3-5 days. The water in the IPA should help remove the “salts” from the wash water while the alcohol acts as an astringent to help drying. Success rate for me with this method is about one in four.
Anyway, those are my two cents worth based on my experience with my Y2000 SL. I hope it is helpful.
- FD
thanks
