SL/R129: overrevving?? oops
i was driving around off a stop light and making a left turn with the shifter in the b or 1st gear position, pushed it hard and forgot that i didnt have it in automatic
the revs went up to about 6700 for about 3 sec and then i noticed and dropped them back down, i let it cool for about 7 min
is there anything i should be worried about?
I have a question for you......If you put your car on auto D.........and floor it in between gear shift what your RPM.......?? Did it go to 6700rpm between gear change......??
before the chip it would shift around 5900 rpm in D mode
i might be crazy but i think it may have cleaned up things a bit, it shifts nicer but that may jus be placebo
ill get back to you on that.mark
but sometimes, ill hit the rev limiter in 1st gear if the car is like rilly hot (6200K)
mark
mark
.....your car start off on 1st gear......?? did you get that Renntech 1st gear start off tranny for you SL...??..... I know you got it for the E500....... How is it....? It is any quicker.......?
no, i usually manually shift. or i press the kickdown with my toe to put it into first.
and i got rid of the renntech frist gear in the E500 because it shifted like pure ****. so now i manually shift the E5 if i want to drive "german"
mark
