SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Dash backlighting
Old Jul 21, 2006 | 12:09 PM
DANSMB's Avatar
97 SL320 Sport, Black. 2003 Denali XL, 2002 Gmc PU, 84 Mustang race car.
Dash backlighting
I asked this on another forum and got no response so I will try here. My car has no backlighting for the 3 center dash vent thumbwheels, is it supposed to? Where is the bulb and how do I change it? It's a 97 SL320 Spoet.
Thanks,
Dan
Old Jul 21, 2006 | 12:49 PM
HLG600's Avatar
2009 SL63 AMG
Is it from behind the dash? If it is, then it might be a tricky job to remove and replace. Call up MB, see what their cost is. If that's too ridiculous, then find an independent MB Mechanic.
Old Jul 21, 2006 | 01:34 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Thanks,
Dan
There are small bulbs inside the vent unit. You'll need to remove the unit, and it takes about 10 minutes.
First thing is to remove the storage compartment immediately above the control unit. Then pry-off the bezel that snaps in place over the thumbwheels of the unit -- this exposes 2 or 3 screws. Remove the screws and pull the control unit out.
If you need further help, email or PM me...
Old Jul 21, 2006 | 03:40 PM
DANSMB's Avatar
Thanks, thats the info I needed, I will look at it this weekend.
Dan
Old Jul 22, 2006 | 05:34 PM
bobterry99's Avatar
Dan, someone on the other forum corrected me. You don't need to remove the control unit to replace just the 2 bulbs for the thumbwheels...Just remove the bezel.
Old Jul 23, 2006 | 05:31 AM
Pigzmickey's Avatar
1998 SL 600 ///AMG. 1997 SL 320. 1999 SLK 230K. 2001 BMW R850.
I think you need to insert the key in the lock and a little pointy thing in the hole beside the lock, then you remove it. I did have a vid on this once, if you have trouble with it PM me.
