SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: 12v. power point
Old Jul 30, 2006 | 04:33 PM
jshape's Avatar
12v. power point
Has anyone installed a 12volt power outlet in the flip-up sunglasses compartment in the dash where the optional MB phone would have been? Seem like a good spot to put my V.60 phone or to hook up a radar detector. Taking out the false back I found that there are three cords that normally hook up to the MB phone – two have wider multi-contact plugs and one is a narrow bayonet plug. Does anyone have a wire diagram showing what these wires do? Has anyone done this before? Any information would be appreciated.
Old Jul 31, 2006 | 06:23 PM
mebeJOE's Avatar
SL500 2001 Formula 1 Edition;
This can be done very easily.
You need to go to the dealer and get the "keys" to take out the radio and heater unit (under $10), then it is an easy matter to remove the ash tray, remove the phone box (screws in back), drill a hole in the back, route the wire behind the dash, and tap into the 12 volt power at the cig. lighter.
I installed a Sirius radio this way, and put a 12 v. under the passenger side of the dash board. See this thread:
https://mbworld.org/forums/sl-class-r129/143178-here-s-what-i-did-box-dash.html
I also have a radar detector, but I just use it on long trips, so I keep it in the center console and only put it out when I need it.
Old Aug 1, 2006 | 09:22 AM
jshape's Avatar
Plug
Thanks for the suggestion.
On the same topic, does anyone know if it is possible (and how) to splice a 12v. power plug into one of the two wires that have 12 point plugs for the phone?
