SL/R129: sl500 soft top problem
Is there a way I can manually open the front latches so I can put the top down? Any help would be greatly appreciated.
Before you try anything manually, try pulling at the top from the outside and in, rocking it. It may just be stuck. It happened to me once and thats how I got it down when mine failed. Persevere for a few minutes and let me know how you get on.
Thank you for your reply.
The problem was the driver side hydraluic realerser or what ever you call it. It was leaking oil and would not open the latch. I replaced it and now it works perfect. Took me an hour to replace it and the part was about $150.
Tip DS
