SL/R129: Transmission Trauma
My suspicion is that the trans is low on fluid and hard cornering causes the low fluid to shift to one side causing the hydraulic pump to cavitate and suck air. When that happens the transmission cannot hold any gears. Later in the day I tested this theory on a hard corner and while I did not get a complete loss of gearing, I did get hard mis-shifts (I believe the ECU goes into “high pressure mode” and raises the pump pressure when it detects low pressure problems and this causes very hard shifts).
Adding/changing the transmission fluid seems to be an area of big controversy. MB says don’t touch and even seals the fluid level check point. Others have changes the fluid in theirs. Should I just have it changed (I’m afraid MB will cry foul) or should I get out that jar of Vasoline and my wallet and go see the dealer?
Any thoughts or suggestions would be appreciated.
Thanks,
- FD
That was at least 5000 miles ago. No problems since then.
If you take it to a dealer shop around. On some things the prices vary widely. For example, Downtown Mercedes in Los Angeles charged me $460 for B service. It is only about $200 at House of Imports in Buena Park.
Thanks,
- FD
Dodged the bullet on that one. . . .
Thanks again,
- FD
