SL/R129: Loose Cigarette Connector
300E 2.5; 2001 SL500
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
Is there a way to repair a loose cigarette connector? I try to use an adapter for charging my ipod, only for it to disconnect regularly when hitting small bumps in the road.
1998 E320, 1994 320 SL,2000 Ford F 150.1997 Gixxer 1100
Loose Lighter
There are a couple of small tabs in the housing that are now too recessed. Use a non conducting tool to pry them back towards each other and that should do the trick. If you use a screwdriver, it will pop the fuse. Been there so I know.
97 SL500
In a pinch I've used a shred of paper folded over and over to get some thickness and used it as a shim to create the same effect as the adaptor I speak of...not elegant, but it works. Folded paper is right up there with silicone and duct tape in my book
![Red face](https://mbworld.org/forums/images/icons/icon11.gif)
I'll try the paper tip this evening although I'd like a permanent solution. Somewhat of a neat freak! Please let me know if you find a pic of the adapter for the adapter! smile
Im sorry, but would you give me an example of a non conducting tool? I remember dropping a dime in the lighter and blowing the fuse! smile
When my phone charger kept coming loose, I simply used a ball point pen to force the tabs closer and snugged the charger. I did all of this while waiting for traffic lights to change. Quite simple.
97 SL500
