SL/R129: R230 AMG wheels on an R129?
Benz/Bimmers/Vdubs
Hi...I'm planning on purchasing a set of AMG wheels that came from a 2003 SL500to be installed on my 1994 SL500. They are 18x8.5 ET30 frts & 18x9.5 ET33 rears. Does anyone know if there are any fitment issues with these wheels? Any pics too? Thanks.
Mark
Benz/Bimmers/Vdubs
HLG600 - what size lug bolts do I need to use? Did you have to use spacers due to the higher offset? Also, what's the model/type AMG wheels are those? Thanks for the info and pics. Do you have any more pics (close up or angle shots)? Thanks again
James Dyer (11-14-2020)
Benz/Bimmers/Vdubs
Benz/Bimmers/Vdubs
HLG600...I have one more question, if you don't mind. Are you using spacers behind the wheels? If not are the wheels rubbing on the inside? Since the AMG wheels have an offset of ET30 (frt) and ET33 (Rear) I was thinking of placing a 5mm spacer to come close to the recommend offset of ET25 (frt) and ET23 (rear). If I use the spacers I may not need shorter bolts. If you have no issues with your setup then I might just do what you did and use shorter bolts. Thanks again
Benz/Bimmers/Vdubs
I haven't decided on the tires yet. I was going to check the "Tire Rack" site for recommendations. What tires are you running?
Dunlop SP Sport 9000
http://www.tirerack.com/tires/tires....=SP+Sport+9000
245's up front with 275's in back. Excellent tire - both in dry and wet.
Benz/Bimmers/Vdubs
245's up front with 275's in back. Excellent tire - both in dry and wet.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
I thought I had all my answers questioned but I do have one more
