SL/R129: R129 Speed Does Not Change Radio Volume
'96 SL600, '05 S55 AMG, '06 C230
In my '96 SL600, the standard MB factory Bose radio is supposed to change volume as the speed of the vehicle changes - increasing speed should produce increased volume. My volume remains constant regardless of roadster speed. The radio/headunit has been changed and the problem still exists. I also know there is a wire that sends a signal to the radio/headunit indicating vehicle speed, but I do not which it is.
Question #1 - Can someone tell me which wire going into the back of the radio/headunit is from the speed sensor? If I know the wire, I can monitor it for a signal while driving.
Question #2 - Can someone provide the circuitry and/or component(s) that create the vehicle speed signal? I suspect the speed sensor has failed.
The speed signal comes from the instrument cluster and goes to the climate control unit and the radio. It is a green wire with black stripe. The simplest way to check the signal would be to monitor it through climate control diagnostics. See test #18 here: http://www.benzworld.org/forums/r129...ml#post1879667.
The link I posted above is for '97 and later R129s. For earlier cars see this link: http://www.mercedesshop.com/shopforu...ad.php?t=86546.
