SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: help diagnosing a particular coil pack
Old Aug 29, 2007 | 04:46 AM
Just Some Guy's Avatar
1997 SL500, 1994 Impala SS on steroids, 2007 MV Agusta Brutale 910R
I know my car needs a coil pack, it will stumble at idle occasionally and once threw a code stating there was a misfire, but im not sure which cylinder it is.
Is there some sort of a simple method of spotting the bad coil, or do i HAVE to plug it into the diagnostics machine and check the ohm readings?
Old Aug 31, 2007 | 02:32 AM
anybody? bueller.....bueller...?
Old Sep 1, 2007 | 08:01 PM
Lincoln's Avatar
97 SL500
I can't help you diagnose but I can share my experience with you. I had one go bad so the shop was able to immediately determine which one and replace it BUT less then 100 miles later another one went bad so we replaced the rest of them. The tech told me the dealer he worked for would only replace all of them at once b/c a coil pack going bad can take out DME which is considerably more expensive to replace then all 8 coil packs. I don't if how common that is but it is believable.
Old Sep 2, 2007 | 02:37 PM
Thanks so much for your response, I have been considering changing them all as I heard a similar story, something along the lines of once one goes the computer trys to compensate and stresses the other coil packs in the process. What exactly is DME?
Old Sep 2, 2007 | 02:55 PM
Lincoln's Avatar
97 SL500
The DME is the engine computer. There are many different references to this device and for some reason DME is what sticks in my head, as opposed to ECU or other names that I've heard.
Old Sep 3, 2007 | 09:52 PM
smckee's Avatar
1994 SL500
Bad Coil
I had an experience with my 1994 SL500 which has two coils. One went bad. Had me fooled for a while. Replaced all of the plugs and wires but still had a miss. Traced the miss with a timing light to the four wires that went to one coil. Bought a new coil and the car ran great. The car lost power coming home one day. It would still do 90 mph even broke. It just wouldn't get to speed as fast.
Good Luck:
