SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Problematic air conditioning system
Old Sep 3, 2007 | 11:23 AM
kyericho's Avatar
SL320
When I switch on the air conditioning system, it takes something like 10 to 20 seconds before there is any air blowing to the outlets in the front panel. This only happens recently, and the air conditioning system has been running fine for the past few years. Mines is a 1997 SL320.
Has anyone seen this before? Is it a problem with the climate control? Or something else?
Please advise...
Espana
Old Sep 12, 2007 | 09:55 AM
Hisrange's Avatar
'93 600SL
Yeah mine does that too...have to play with hitting the numbers to finally make it work. Its weird for sure.
Old Sep 12, 2007 | 04:35 PM
kstreufert's Avatar
2017 C300W4 2018 GLE350W4 2018 E400A
I am having the same problem with my 1996 SL320. I feel pretty certain that the center vent flap vacuum actuator above the blower motor is going bad. I will be replacing mine in the next couple of weeks. I will let you know if that solves the problem.
Old Oct 1, 2007 | 07:15 AM
kyericho's Avatar
SL320
Is there any update? Were you able to fix the problem?
Old Oct 2, 2007 | 02:36 PM
kstreufert's Avatar
Haven't gotten to it yet. I am planning on changing it out this coming weekend.
Old Oct 3, 2007 | 12:30 PM
kyericho's Avatar
SL320
Just curious. Do you get any air blowing out of the vents (left, right and center) vents? Mine don't until something like 10 to 20 seconds...
I am also researching into the problem now. I will let you know if I find something interesting.
Eric
Old Oct 7, 2007 | 09:39 AM
kstreufert's Avatar
My car blows air through the side vents but not the center vents. I ordered the replacement actuator from the dealer but when I went to pick it up it was the wrong part. The dealer has reordered the actuator but as a result of the Columbus Day holiday it will not be in until Tuesday. I will give you an update later in the week.
Old Oct 12, 2007 | 02:49 PM
kstreufert's Avatar
I picked up the new actuator from the dealer on Wednesday and installed it that evening. So far no problems. Since your are not receiving any air from your side vents either the cause of your problem is most likely different.
Old Nov 19, 2008 | 01:34 AM
kyericho's Avatar
SL320
Please advise...
Espana
Could anyone please help? Now, it takes something like a minute before there is any air blowing to any of the outlets in the front panel...
Thanks in advance.
Old Nov 19, 2008 | 07:23 PM
SUHAIL's Avatar
1986 190D 2.5 (W201), 1999 SLK230 (R107), 2000 S500 , 2001 SL500, 2005 G55 Grand edition 327 of 500
Thanks in advance.
I seem to have another problem, the AC seems to shut off at accleration and at high speeds. Any suggestions
Old Nov 28, 2008 | 12:23 AM
security030's Avatar
gfefd
air conditioning
My guess is there must be problem in the electric relays which releases supply to the fan blower of the air conditioning
