SL/R129: Fuel Filter 1991 500SL
I want to change the filters (air and fuel) on my 500SL, but have run into a basic problem.
The air filters are easy to locate and, "mission accomplished". But, can someone please tell me the location of the fuel filter?
I hope it's not that 3 inch long canister beside the distributor on the driver's side, mixed in with all that "plumbing". If it is, should I attempt to replace it myself? Will I need any specialized tools? Or is it something that has to be done by the professionals?
Thanks for the help and any input.
Sincerely,
Frank
Of all the maintenance tasks, this one can be dangerous; for obvious reasons. Gasoline will inevitably leak and drip, immediately creating a quantity of fumes. Any spark from a tool, electrical arc, broken bulb in a work light, etc., and you are caught in a very, VERY dangerous situation.
Changing the fuel filter can be done safely using special clamps or rubber-padded vise grips to clamp the fuel lines while the filter is changed. Do not attempt to change the fuel filter without properly clamping the fuel lines. Otherwise, you will end up with gallons of fuel on the floor faster than you can say an expletive or two. Other than the precautions, simple hand tools are all that is required.
If you're new to this sort of thing, I would strongly recommend finding an independent shop to replace the filter for you. Watching how it is changed properly will go a long way in protecting you in the future. You can buy the filter yourself, so that you provide the brand you want, and have the shop install it for you. On a professional car lift, time to change the fuel filter is about 15 minutes.
BTW – Congrats on changing the air filters!
Cheers,
Jeff
I really appreciate your help and advise.
I did look around the fuel tank, but obviously missed it. I'll look more carefully in the morning.
Changing a fuel filter is not a new process for me, but it is on this car. I purchsed it about 1 yr. ago as the 2nd owner. It's in great condition at 120k miles. This one has replaced a 4-speed '67 250SL.
Thanks again for your help.
Sincerely,
Frank
