SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: SL 300 oddometer
Old Sep 17, 2007 | 01:48 PM
mglb's Avatar
SL 300 1992
SL 300 oddometer
the oddometer on my 92 SL 300 does not work ,the speedo works, and I guess the signal to the instrument is the same ,the oddometer appears to have no damaged gears and if turned manually works fine could the printed circuit be faulty ? I have been quoted £150 by bba reman for a test and repair on the circuit board and I have been quoted £150 for a second hand unit from a SL500 would the v8 unit fit the 6 cyl car ? which would be the better option? or does anyone have any ideas? thanks for looking mark
Old Apr 27, 2009 | 05:08 PM
SailawaySG's Avatar
1991 SL300
Have you removed the motor that runs the odo? There,s a gear that breaks on the shaft of the moter. I had the same problem and found a company that makes them,DNA speedometers, 813-875-8226. $50 You have to drill a small hole to get to one screw,be gentle. You should not be able to turn the odo manually.
