SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Convertible Top
Old Jan 31, 2009 | 11:33 PM
ravinayak's Avatar
1990 500 SL
Convertible Top
I it possible and how to disable the electrical control of soft top and hard top(it does not work anymore) so that I can use it manually?
Old Feb 1, 2009 | 01:30 AM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Unfortunately for you, the top is hydraulically actuated and locked in position. It would not be practical to manually raise and lower the top, as it really takes 2 people to lift it out of the well that it stows in when down.
Nick
Old Feb 1, 2009 | 12:07 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
You can manually raise and lower the top without disabling the non-working system. The instructions are in the owner's manual. You use the narrow 10mm wrench supplied with the car's original tool kit to open and close the latches for the top and the cover for the top storage compartment.
Still, if you want to disable the system, simply unplug the top control switch.
Old May 12, 2009 | 01:37 PM
DropTop430's Avatar
02 clk 430 cabrio
i dont have a owners manual... so how do i do it manually on my 2002 clk 430?
Old May 13, 2009 | 12:33 AM
Bigdot's Avatar
some
ask your CLK buddies.
Old May 15, 2009 | 07:44 PM
dukebebe's Avatar
Looking at a 1997 500SL currently I drive a 84 E-320 great car have no complaints at all . Now looking for the SL as the weekend fun car..have been scared off by comments on the electrical harness and the convertible-top hydraulics always going bad and expensive to replace. True or False ?? Anything else They missed ???? Rasputin
Old May 15, 2009 | 07:51 PM
dukebebe's Avatar
Need help on purchase of 129
NEW AT THIS YOU SEEM TO BE THE EXPERT AFTER READING OTHER COMMENTS.TELL ME ABOUT 1997 500sl ELECTRICAL HARNESS AND HYDRAULIC FOR CON-TOP. CURRENTLY DRIVE A 124 E-320 1984 GREAT CAR.
Old May 17, 2009 | 03:48 AM
lynns's Avatar
2000 SL500
Please see R129 Owners Manuals, Service Sheets, Products, and download site for early AMG R129
Old May 17, 2009 | 11:45 AM
bobterry99's Avatar
The electircal harness is a problem limited to '93-'95 cars, though the '93 300SL is unaffected.
If you own a car long enough you will probably have to have some work done on leaking hydraulics. These repairs normally are not expensive; and if you are willing to do some of the work yourself, they are actually cheap. Cylinders are not difficult to remove, and they can be rebuilt for around $40 by people like Dennis Ficken.
