SL/R129: Center Console Removal
The right side window is acting up, but works fine when I use the top release switch, so I'm pretty sure it's the window switch - just needs repair or replacement...
If you read through the following link it should help you out. There are also disassembly videos for the R129 center console.
http://www.benzworld.org/forums/r129...g-console.html
Hope this helps!! If not, there are a mass of guys on here that have an endless amount of knowlege. Their awesome!!
Cheers,
I think I can get to the right window switch without removing the entire console, maybe just the screws around the ashtray...
BTW - if the radio is disconnected - this is not mentioned. It has to be re-programmed. If you don't have the code, don't disconnect the power from the radio !!!
