SL/R129: PROBLEMS WITH ROLL BAR '90 500SL
My roll bar with using the dash button will not go up or down. I replaced all fuses, checked rear pump, replaced all fuses, & cleared all codes X-11 box except Code 20. I need to know the code 20 diagnostic information - I think this is where my problem lies. When I press the top button to go down the windows roll down but the roll bar is not operating. I can hear the rear pump operating. Thanxs. Joe
Code 20 means the system recognizes the hard top is installed on the car, so generally it is not a fault.
You can check roll bar codes through socket #7 of the diagnostic connector. You can count the code pulses with a wired LED or by watching the malfunction lamp in the instrument cluster.
If the pump runs when you press the manual control switch, then I believe you likely have a mechanical issue. Did the roll bar automatically deploy? If so, then it must be reset by pressing the manual switch as if to raise the already-raised bar and holding it there for about 10 seconds until a "click" is heard.
