SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Hardtop Question
Old May 5, 2009 | 05:57 PM
Lucky Strike's Avatar
Changes Daily
Hardtop Question
Are there any changes made to the hardtops between 1990 and 2002? For instance will a hardtop from a 95 SL fit on a 2001 or vice versa? Thanks in advance.
Old May 5, 2009 | 10:33 PM
Bigdot's Avatar
some
some minor changes, i heard that the later ones (rounder, less boxy) wont fit on an earlier one very well.
Old May 6, 2009 | 03:01 PM
pcviewer's Avatar
2006 Aston Martin Vantage
I believe starting with '96 (if not, '97), the rubber seals over the door windows flap outward where as the '95 and earlier do not. This outward flap will not allow you to close your door properly if installed on a '95 and earlier model (if it installs at all). For '96 and newer, the window lowers a bit when the door is opened and raises when closed.
Old May 7, 2009 | 12:01 AM
Bigdot's Avatar
some
thats what it was!
